Picked this up last week, took it for a 14 mile ride today, runs like a charm!
New Moped
Re: New Moped
Sweet Suzi!
Re: New Moped
Nice . Looks to be in prime condition . ;)
Re: New Moped
Sadly it has a dent in the front fender and in the headlight rim. but other than that just a bit patinated. I wont do too much about it though because it's fully original as it is.
Re: New Moped
Good you want it original .
As for the dents , I've had good luck cutting hard wood to match the curve of the fender . Placing the dented area in the concave cutout . Narrowing the the cutoff portion of the wood to a workable size , creating a mandrel . Add a decent hammer and a few well placed 'whacks' and something more acceptable emerges .
Here's a before :
And , after :
Re: New Moped
What a great result!
I am just afraid to damage the chrome, as it is in mint condition on both fenders.
Re: New Moped
> both fenders.
That's exactly why using hard wood works . It's softer than chrome .
Place a bit of cloth between the wood and chrome . Don't worry about the fender inside .
Re: New Moped
> > both fenders.
> fender inside .
So just i clarify: Do i place the outside of the fender against the hardwood and cloth and then hit the inside with the hammer?
Re: New Moped
Gentile tappy taps on a wooden dowel or form is what I would do with the fender well supported. (edited)
Re: New Moped
Use a simple contour gauge :
to find the curve of your fender .
Cut hardwood to that^ gauge curve .
Line the form ( cutout ) with heavy cloth .
Reshape the cutoff ( mandrel ) piece to be more workable and use that on the inside of the fender to be 'hit' with a hammer .
Or , if the end of the fender has the same contour as the dented part , simply hold the end over the wood and trace the contour onto the wood , then cut .
Re: New Moped
Use an appropriate size piece of pipe and tap it out from the underside. I've actually used an old base ball, lol. Worked great. (edited)
Re: New Moped
Anything that has a similar radius can be used as a mandrel . ;)
Re: New Moped
I thank you all for the great advice :D
Re: New Moped
Here in the USA that is not considered a moped, it is only registered as a motorcycle.
Re: New Moped
> a motorcycle.
I wouldn't know about classifications in the USA .
It's a 50ccm kickstart operated motorcycle which in Europe is classified as a moped
