I need to strip the paint off the forks and was thinking about pulling the springs, buffers ,and seals. Should I use axle grease when I reassemble?
Grande Forks
Re: Grande Forks
Okay, pulled tubes and one of the seals is rolled. I pressed it back but it's split. Parts book shows part no. Only no size . Found seals at Athena site, no Grande shown. Can I just leave it as is? Or will it pump grease? I Musta done it when pulling the tube, as no oil or grease on the forks.. bummer
Re: Grande Forks
You have to know that anything you expect that seal to hold is going to be in a rag before long .
If all else fails , pull the seal and measure it . ID, OD & Width/Thickness .
Search using those #s . You'll find new seals soon enough .
Re: Grande Forks
Thanks for the tip PD. Will do
Re: Grande Forks
I've bought seals for grande forks. But I'll be damned if I could install em
Re: Grande Forks
> install em
Were you drunk or ???
Re: Grande Forks
What's the problem Terbo? Hey! Could you measure and send ID & OD?
Re: Grande Forks
So I picked out the seal in pieces could still read the numbers 28x40x7.
Re: Grande Forks
So, my years of watching detective shows paid off. I forensically reconstructed the formally massacred oil seal. By finding a unmolested outer piece 7mm I rolled out to 40mm. OD By powers of deduction, I concluded the ID at 28mm. Also I found the numbers still visible when I tilted it to the sun.. ;)
Re: Grande Forks
Fork seals are really really easy to install. Nice detective work, throw that in the wiki!
Re: Grande Forks
Thanks Nick! Lotta moped thieving your way man! Keep your head on a swivel!
Re: Grande Forks
So Nick, finally got the seals and like Terbo said this are MFers to set. Bad enough picking them out piece by piece. Any tips? I thinking of tapping them in with a socket maybe?
Re: Grande Forks
