i know this seems an out of the ordinary? But what is under the flywheel on the left side of my a35 ? Because it has a cdi? Is that stator points or what?
Stator coils.
Yeah, it should just be a pair of coils.
Obviously there shouldn't be points, given you have a CDI ignition.
Wound coil hubs 4 of em 3 lights one ignition.
Works on a hall effect sensor mounted on the coil or later in the case as a separate iggy circuit.
And a35 doesn't use a CDI. It uses a TCI. Different sort of electronic ignition, that's why there's no pickup coil.
Whats the tci stand for?
Transistor Controlled Ignition.
I learned about such things while trying to sort out the ignition on my Derbi.
