Re: Petcock conundrum.
P D /
> Dirty30 Dillon Wrote:
> If sounds like you have poor fuel flow. I am guessing the reason you
> need to run start it down the drive is that fuel is trickling in so
> slowly that it takes time to fill the bowl.
> I'm guessing if you left the petcock on for an hour after being left off
> all night, it would start just as well.
Likely more of an evaporation problem than a flow problem , as no problem after start .
Does your petcock have a PRIME position ? Try switching it there for start up .
If no Prime , simply turn the petcock to ON for a minute or two before starting .
That will allow the bowl to fill completely and the motor won't have to work as hard sucking the fuel into the mix .
