Re: Honda GIZMO engine rebuild
P D /
> Paul Stratman Wrote:
> Head, base, exhaust gaskets. A set of points, maybe a stator, and a
> voltage regulator and coil.
The Head and base gaskets can be hand cut .The exhaust I'm not sure which type you need .
Points you'll likely have to match .
Electrical is pretty common , matching shouldn't be much of a problem .
They probably used what ever parts were on the table at the time .
That means parts are available , just that they might not be specifically listed for your exact bike .
