Honda GIZMO engine rebuild
Hello!
Where can I get parts?
Re: Honda GIZMO engine rebuild
> Paul Stratman Wrote:
> Hello!
Whatcha need? Got a pic and year model? (edited)
1985 Honda Hero Gizmo
That is not a Honda, just a Hero. It's an Indian manufacturer. It was a joint venture between Honda and Hero but it's not a Honda Gizmo. (edited)
Hero!
> Hero!
It's a cool bike, pretty uncommon. It came out of HandyBikes in Columbus, just down the road from me. Most Hero moped used clones of bigger manufacturer motors but I don't know what the Gizmo motor is a clone of. The kickstarter looks pretty unusual. Might be a Peugeot clone, but what parts do you need? (edited)
Head, base, exhaust gaskets. A set of points, maybe a stator, and a voltage regulator and coil.
It has POINTS,not electronic ignition? What year is it. The Gizmo had a variator,I believe.
Add a full face helmet to the list of parts, if you are attached to the lower part of your face, because one day you might not be.
1985, it has a v-belt centrifugal clutch. Can't get parts, oh well...
The Head and base gaskets can be hand cut .The exhaust I'm not sure which type you need .
Points you'll likely have to match .
Electrical is pretty common , matching shouldn't be much of a problem .
They probably used what ever parts were on the table at the time .
That means parts are available , just that they might not be specifically listed for your exact bike .
That centrifugal clutch is a variator. Makes all the difference.
🇮🇹💦 Of the Loin /
Hero doesn't super make their own designs
so this was likely copied off a commodity vehicle so you can probably find it
I have a later model Hero and my engine is a clone of a Peugeot 102. I have gotten a few things from DOS cycles.
