Hello!
Where can I get parts?
Hello!
> Paul Stratman Wrote:
> Hello!
Whatcha need? Got a pic and year model? (edited)
That is not a Honda, just a Hero. It's an Indian manufacturer. It was a joint venture between Honda and Hero but it's not a Honda Gizmo. (edited)
Hero!
> Hero!
It's a cool bike, pretty uncommon. It came out of HandyBikes in Columbus, just down the road from me. Most Hero moped used clones of bigger manufacturer motors but I don't know what the Gizmo motor is a clone of. The kickstarter looks pretty unusual. Might be a Peugeot clone, but what parts do you need? (edited)
Head, base, exhaust gaskets. A set of points, maybe a stator, and a voltage regulator and coil.
It has POINTS,not electronic ignition? What year is it. The Gizmo had a variator,I believe.
Add a full face helmet to the list of parts, if you are attached to the lower part of your face, because one day you might not be.
The Head and base gaskets can be hand cut .The exhaust I'm not sure which type you need .
Points you'll likely have to match .
Electrical is pretty common , matching shouldn't be much of a problem .
They probably used what ever parts were on the table at the time .
That means parts are available , just that they might not be specifically listed for your exact bike .
That centrifugal clutch is a variator. Makes all the difference.
Hero doesn't super make their own designs
so this was likely copied off a commodity vehicle so you can probably find it
I have a later model Hero and my engine is a clone of a Peugeot 102. I have gotten a few things from DOS cycles.
