> Alex DjFlaco Wrote:
> Yea I'm going to order a new piston Mike. Well I guess the whole
> thing.just wanted to see if I can even get a spark after releasing the
> piston.
Don’t just order a piston, it to be matched to the cylinder #/or Just buy a cylinder kit, don’t just try to knock the piston down make sure you pull the cylinder a few inches up so not to bend the crank,
There’s a good chance that the crank and crankcase looks just as bad as the cylinder so full engine rebuild may be in order so don’t order nothing until you take the whole thing apart
