Re: tomos biturbo
Reeperette /
The 2-piece adds an extra advantage on being able to select where you wish to apply the power, see.
Cause of the way such things work, sliding it longer or shorter affects where you get more boost on the two piece unit.
Shorter allows it to respond better at high RPM, giving you more on the top speed end, and longer allows more power-response at low RPM, resulting in better takeoff.
It's worth the lil bit extra to get the 2-piece, but I've heard it's best to weld it instead of clamping it to avoid leakage once you do have it set where you want it.
-R
  tomos biturboTopic by: corypoopoo corypoopoo 07/03/02 10:33PM
  Re: tomos biturboRe: Reeperette Reeperette 07/04/02 08:49AM
  Re: tomos biturboRe: IsLookingUp IsLookingUp 07/04/02 09:57AM
