Need help with high performance carburetor
Alven Narcisse /
I have a puch maxi and was wondering if this carburetor would be compatible with my moped.
Re: Need help with high performance carburetor
Not sure about compatibility, but if you buy a $30 "performance" carburetor, don't expect to get the same performance as a $130 carb.
short answer is no
Lol no. Wayyy too big. Not for a two stroke either.
Also, just changing a carb isn't going to do much.
Remember whenever you change the carb, exhaust or cylinder you need to re tune the carb by changing jets. If you don't, your cylinder/Piston/bearings can seize destroying your engine. The oil is in the gas right.
If you don't want to tear the engine down but want to increase performance. A 15mm bing carb, matching 15mm intake manifold, and expansion chamber exhaust is the way to go
Probably Fred /
Stock puch cylinder or mild piston port kit (PP) a 14mm bing and 14-15 intake is what you want, 14 mm bing starts easier when cold/bike been sitting for awhile and it has a bit more low end then a 15mm bing, 15 mm bing makes a bit more power mid to high rpm though,
They both have near the same top speed given the pipe is the limiting factor many times but 14-17mm carb for stock cylinder or small/mild PP kit/build it’s pretty much all you’ll need
Alven Narcisse /
Thanks
Pussy Licker420 /
> the gas right.
It’s not that big but yea sha15 is tiny
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
its performance because its colorful. I think this is a well established rule
Juleon Cotillon /
That carb better come with vtech and an adjustable cam gear. Itll rip your face off when it hits 30mph. Seriously though, that carb is pretty bonkers. I dont think youll be able to find parts for a rando ebay one with the title "Performance carb" on it.
Hell, just buy it and post the results.
Dirty30 Dillon /
It's just a bad copy of a PWK. Which was designed for 2t applications.
