Re: Beach Riding
Probably Fred /
Yeah get a magnum or tube frame puch bike unless you’re like 146 pounds, ringing wet ,
Magnum/tube frames have good swing arms and could take almost a half inch larger width larger tire, you can get a magnum swing arm for your maxi but rear fender and other things may have to be modified,
No matter the Maxi suspension is nothing like a tube frame suspension, if you’re going to ride on sand or off-road you need to upgrade your suspension
