Signal Flasher Relay
Hi!
Can someone tell me where the Turn Signal Flasher Relay is to change it? Is it on the left handlebar or where?
Thank you,
Re: Signal Flasher Relay
Hard to say without knowing what you're working on
I think it is under the horn cover up front, will look at mine when I get home from work.
Yes - QT50 turn signal relay is behind the horn cover.
> get home from work.
My bad on this.i had towny on my brain...glad you both were around to clear that up.
Anne Brown /
Thanks guys!
I appreciate all the help I can get
