Dropped c-clip down into a35 engine.
Taking wrist pin clip off the piston and i heard dink. It sprung off the needle nose pliars. I looked all over the room for the clip to no surprise i couldnt find it. Looked around for 30 minutes knowing i hadnt covered the engine after removing the head. I peaked in there it sat down in the case resting on the bottom of the crankshaft. I seen i only had a 1/8 of n inch width of room to reach and recover the clip. Or i would be paying someone to split the case because you can't run any engine with foreign materials and expect to last very long. Make a long story short! Duct taped a bread tie to an allen wrench and burnt off the coating formed it into a hook an 2 minutes later on the 3rd try i hooked the clip and pulled it out of the bottom of the case. Super happy wasn't at the time. Gonna cover the motor with a rag cloth etc during any work when you mess with piston and rings people.
Re: Dropped c-clip down into a35 engine.
Pushrod Fifty /
Awesome recovery. I use cheesecloth to cover up the crankcase. it bends around the crank and studs real easy and its dust free out of the bag. Home Depot- $3.00.
Good tip! i have a home depot 1 mile from my house. Thanks.
♣Slew Foot♣ /
Never assume that it didn't fall in there.
The universe is a cruel dominatrix...
