RE: TOMAS BENT FORKS
DOUG D /
Hello MOPED MAMA, could you tell me if the coil on a Points Tomos is the same as the coil on the CDI TOMAS? I have 1-Tomos TT missing the coil, 1 rear shock w/spring around it (need top bolt for it) and both petal arms bent, can you help with mabe good used parts? NEVER DID HEAR BACK FROM THE OTHER PEOPLE WITH PARTS. HA! MY LUCK. Thanks for reply, Doug in VA.....
  TOMAS BENT FORKSTopic by: DOUG D DOUG D 11/13/00 01:47AM
  RE: TOMAS BENT FORKSRe: tim tim 11/13/00 05:51PM
  RE: TOMAS BENT FORKSRe: DOUG D DOUG D 11/13/00 09:01PM
  RE: TOMAS BENT FORKSRe: moped mama moped mama 11/17/00 09:55PM
  RE: TOMAS BENT FORKSRe: DOUG D DOUG D 11/17/00 10:13PM
  RE: TOMAS BENT FORKSRe: DOUG D DOUG D 11/27/00 07:44PM
