Has anyone ever straightened out bent forks, I have 2 Tomas 93 and 94 Top Tank modles and both have front end damage. Bought at city inpound auction, any help out there? dwdoogie@webtv.net
TOMAS BENT FORKS
RE: TOMAS BENT FORKS
I have a set of used tomos forks if u want them.
Thanks Tim, I am 49 and the moped riders are the best, I have ran into yet! And that`s what it`s all about! Doug Davidson
hi if you ever need tomos parts let me know. ihave new and some used.
Thanks MOPED MAMA, I have some people that is suposed to get back to me about Forks and Headlight assembly, but still waiting, HA! I have 3-Tomos Top Tank mopeds, I will go over them and make a list up and email you, Do you have a bussiness or is it hobbie for you? Thanks for repling Doug in VA.
Hello MOPED MAMA, could you tell me if the coil on a Points Tomos is the same as the coil on the CDI TOMAS? I have 1-Tomos TT missing the coil, 1 rear shock w/spring around it (need top bolt for it) and both petal arms bent, can you help with mabe good used parts? NEVER DID HEAR BACK FROM THE OTHER PEOPLE WITH PARTS. HA! MY LUCK. Thanks for reply, Doug in VA.....
