What do you bring with you when you ride for tools?!
2 stroke oil
Adjustable wrenches
10mm wrenches
12mm wrenches
Screwdrivers
Tire patch kit
Drinks and food
Bandaids
2 stroke oil
Adjustable wrenches
10mm wrenches
12mm wrenches
Screwdrivers
Tire patch kit
Drinks and food
Bandaids
Spark plugs
Dextron
A 15 year flip cell phone, The stock air pump and tool kit that comes with puch bikes, a tire iron and a 10 year old tube patch kit because on my bikes most only thing that stopped me most times was a flat tire (actually most times it was the original 30-40 year old tire and tube that finally gave away because I liked the look of the reflective strip side wall of stock puch tires)
When you have the most reliable/easy to work on Moped’s in known history you don’t need much,
spark plug, plug wrench, flat head, 10mm wrench, 5mm allen, pocket knife
If that doesn't fix it, I'll lock it up and catch an uber
channel locks,wire snips and 200mph tape
I have multi wrenches for airtanks two vice grips socket extender deepwell sockets open end 10 and 13 mm multi screwdriver ... Tire levers patchkit flywheeltool. It all fits in a caselogic CD pack that straps to the rearrack.
No tools .
My FA50 doesn't even have a place to store them .
There is a piece of bailing wire in the milk crate . I found it on the road .
I hard seized it , once , a few years ago . I did the walk of shame .
Zip ties for whatever rattles off.
Matches. If the damn thing can't get me home into the fires of Hell with it.
It's for extended rides. Usually I end up walking it home like an ugly drunken prom date...
Usually a flat or a badcaseside bearing. U could run it but your better off not...
I only carry stories about how much I don't need tools
Thanks for the posts. Im building a riding bag. Pics soon.
Is that anything like a witches broom ? ;)
I'm thinking I better take notes and stock my back pack. :/
i have a lil' green bag ( doo do do dooo do)
that i carry around with
leatherman
crescent wrench
10mm socket attached to a 1/4 drive ratchet
5mm allen
zip ties
wire
fireworks
beer koozy
a rag
2 stroke
a double ended alligator clip wire
LED headlamp - can be used for a headlight and also has red beam for emergency tail light.
there is damn near nothing on a moped that you cant fix with that. if you have a lot of 11 mm nuts (lookin at you MBK) carry that socket too.
this one time, at band camp, i was able to get the flywheel nut off with the cresecent and pop the flywheel by hitting it with a rock, you can get pretty creative when you are SOL in the middle of nowhere.
weed
6 dollars gas money and. For a qt of oil .
