> ugp * Wrote:
> I ended up with the original 3 speed red Issimo (twins) that was posted
> on the Dos website. It has a Parma kit (48mm?) or something on it. I
> think any V1 Kit would work. But you do Not have the fan to help cool.
> Been running the kit no issues with stock 14/12. About to put the 15:15
> on this afternoon. Still have the side covers. Just need to replace the
> front wheel fender. Mine was hacked and has a nice point that was carved
> into it.
> @stephen can you post a link of that tool that you modified to pull that
> gear? I have only pulled the cover off and inspected the internals but
> know I’ll have to do some preventative
https://shop.advanceautoparts.com/p/performance-tool-tie-rod-puller-w83025/11931868-P
This is the tool I use. All I did was cut the top of the bottom part down enough so it could slip under the gear. You have to grind a little in the back center to make sure the teeth of the gear doesn't bind on it and so it can get the puller bolt center with the crank. $15 tool and 15min of work and you're golden!
