Yellow moby paint
Hi all,
Recently I was tasked with painting the rusted/chipped spots on my '77 moby and I couldnt find much on this website. So I went through at least 3 different colors and found that Rust-Oleum Sunburst Yellow was a perfect match. I got mine for about $5 and I'm thouroughly satisfied with the results.
Re: Yellow moby paint
Rick Bergsma /
Nice , post a pic of your work
Bruce Zapper /
Is that 77 the same yellow that is used for the 80 yellow Traveler? Can you post a pic.?
I'm not sure about that one. I'm guessing they should be the same, but dont hold me to it. Here's a pic
Bruce Zapper /
We are about in the same place I am down to the frame cleaning the tank! Do you have everything to complete it?
Yes sir! I got the engine running a while ago, and now that I have some more time because of the virus I've turned my attention to the cosmetics. I filled the gas tank with evaporust and then coated it with some por-15, good as new. Now I have all the rusty parts sitting in evaporust, it should come together nicely.
I hope you don’t end up regretting that Por-15. I’ve heard horror stories...
> stories...
Too late for warnings . He'll have to live with it .
You can get the paint matched at a body shop if you take a sample to them I used the back of a side cover.
Bruce Zapper /
> stories...
What would you suggest?
Sam is correct, you will not get a better match for that yellow.
> Bruce Zapper Wrote:
> > stories...
Caswell, but only if it had pinholes. Otherwise no coating is preferable. Clean the inside with vinegar or evaporust, and run it. Keep it full of clean, non ethanol gas.
But it sounds too late. Hope for the best, and maybe it’ll last.
Absolutely Caswell
