Re: Gila on Tomos on garelli pipe suggestions
J Dubbs /
> Brandon Weiss (Detective brandon to you) Wrote:
> A gila has the same exhaust port angle as a stock A55 tomos cylinder, so
> dimensionally an A55 designed pipe would likely be a better place to
> start, if you were looking for something off the shelf. As far as Crank
> pipes, he may have difficulty making a pipe that would be a direct
> bolt-on, because your engine/frame setup is non standard. Maybe if you
> get him extremely accurate measurements? I think he uses actual bikes
> for design and fitment though.
Thank you very much and I appreciate it...
This metrakit pipe in the picture is what I was wondering about and if anyone had any experience using it.. do you know anybody who has used this pipe Brandon?
Here's a picture of my other tomos with the Puch 80cc big port metrakit on it... Also I put a picture of the pipe I have sitting on the shelf at home...
does that pipe have a restrictor in it because treats used to have something saying it did but I never opened it...
I definitely have that baffle on my pipe and the version 2 doesn't have that baffle so it would have to be that version 1... Do you think I can run that pipe on the setup with the Gila..
I know I'm going to have to bend that flange and it's pretty tough but I'm wondering if I could use a spacer...
I'd be able to cut a piece of aluminum slice it like a piece of cheese after I get the measurement and put a hole in it...
Thanks man
