Re: Gila on Tomos on garelli pipe suggestions
A gila has the same exhaust port angle as a stock A55 tomos cylinder, so dimensionally an A55 designed pipe would likely be a better place to start, if you were looking for something off the shelf. As far as Crank pipes, he may have difficulty making a pipe that would be a direct bolt-on, because your engine/frame setup is non standard. Maybe if you get him extremely accurate measurements? I think he uses actual bikes for design and fitment though.
