Tuned Garelli Katia
Hi
Nearing the end of a full restoration on a 1975 Garelli Katia single speed. It has the same engine as the Noi so it's been awesome to use this forum to help with the build.
I've used treatlandTV who have been awesome for sourcing the upgrades for the engine. Been the same engine as the Noi it's been useful following what engine kits other people have used so engine spec goes like this:
44.5mm mallosi bore up kit
44.5mm reed valve
BRN head
19mm PHBG carb
MLM people's pipe
The bike frame and suspension parts have been blasted and painted in apple jack green which is a British rover colour.
The shock absorbers are 255mm shocks off a Norton motorbike but I could be wrong, I think there more universal.
Tyres are Dunlop's 3.00-10 scootsmarts which I think make the moped look like it should, which a bit of an upgrade on the original tyres.
When I do start the bike for the first time I've got a few questions.
What's the best way to run the engine in?
What's everybody's thoughts on the single speed rubber clutch? I know there's a few threads on them including using the kickstart clutch as an upgrade, which might be the best option if the rubber clutch doesn't work. But overall how as anybody else got on with them?
Gearing, that's another thing I'm not really looking forward to.
Jamie
Re: Tuned Garelli Katia
That is SO cool! I don't have break in tips, but great work!
Usually I just run it but don't keep it at a constant rpm. Kinda roll on and off the throttle at different rpms. Nice bike.
Please run a filter, you're going to toss everything on the road into that engine.
I have the same pipe and head. I ran a polini kit and diff carb. For break-in just don’t go full throttle for a full tank or 100 miles’ish. A little is ok...but just don’t run it wide open for more than 20 seconds? Basically try and avoid it. Run up and down your throttle range. BRN heads are the best things ever made for NOI. What’s your temps sitting at when your running around nice and warm?(edited)
Your right it won't be running without a filter. I'm so close to starting it, just got the wiring loom to finish off making
Slowly running it in, it's running pretty rich at the moment but rather be that way while it's all new.
Will get round to jetting it properly when it's road legal.
Here's some more photos.
The green really pops when it's sunny :)
Unfinished , but , clean .
It needs fenders , with a mud flap up front .
fukn a that's hot
year of the mini
and also of staying home
Sick bike! I getting mine finished up too!
