Has anyone found risers that will work with the 30mm EBR Hydro bolt spacing?
I have found many sets that work with 32mm-36, but have yet to find anything
smaller.
I started typing this then realized my forks were KX80 forks
But they came with risers for 1" bars, so I used 1" to 7/8" shims which are totally a real thing
Maybe find 1" risers and shim the bars
It’s not the bar size that is giving me issue, but rather the bolt spacing on the triple tree.
Oh these say 30mm height. Sorry
oh cool, thanks Steve, I had not seen those before.
You might consider making a couple risers from hard wood . Paint . Use the current clamps and longer bolts/screws .
You can use the top part of a hobbit handle bar clamp (since separate). But come to think of it, bottom might be the same width aka the whole setup is the same bolt pattern.
or why not just redrill it
gotcha. might be able to make a single bolt down through the middle but I agree looks like the pivot style steve posted are a solid move
That is better I'm my opinion. Cut off the og mounts and mount some single posters.
