Magnum Mini
Hi All
I have heard you can put Maxi suspension on a Magnum and thus lowering the ride height?
Does anybody have and links to builds of this sort? how easy is this to do?
Thanks in advance!
Steve
Re: Magnum Mini
uhhh i have maxi shocks on my magnum theyre 300mm
Re: Magnum Mini
thanks for the info! do they bolt straight on? how is the ride height now?
Re: Magnum Mini
2 left hands 🏍 /
Swap the forks with maxi length. Put a maxi swingarm on and shocks. And that's a mini magnum
Re: Magnum Mini
Here's mine, with tomos wheels and a35
Re: Magnum Mini
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
we been doing mini mags for years, just short shocks and maxi length forks and you're good to go
Re: Magnum Mini
there' so many
My magnum even has the shorter, maxi swingarm
Re: Magnum Mini
Thanks everybody, will give it a go and let you all know (:
Re: Magnum Mini
no groms no blasters /
then put the parts you pulled off the magnum onto the maxi so you have a mangumax, or, if you used another donor, a magnanto or a magnewport or a freemag numprit
Re: Magnum Mini
If you're interested in downgrading the suspension components of a Magnum, why not just get a Cobra instead?
Re: Magnum Mini
if you want to be really cool, use the wheels from a Dart to make it super mini
Re: Magnum Mini
Emil Kniemel /
Can someone post a pic of a mini-mag next to a regular mag? The pic of the one next to the maxi helps a lot.
