Re: Static timing and points gap for 1940s 2 stoke, low compression engine - Zurcher
pat splat /
> el pollo Wrote:
> > pat splat Wrote:
> > cool motor, more details will be appreciated. my guess is crank
> seals.
> > timing anywhere is close enough. are u spinning it the right way?
> its a 2t. as long as timing is right it runs in either direction.
true, two strokes dont care as long as u can adjust timing, theres the rub... i've tried by accident many a time to start a motor the wrong way
and i've gotton the ocasional pop just like the op. Now upon realizing the mistake the motor fires right up.
  Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherTopic by: kenneth Winter kenneth Winter 02/13/20 11:30AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Probably Fred Probably Fred 02/13/20 11:37AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/13/20 12:09PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Dirty30 Dillon Dirty30 Dillon 02/13/20 12:28PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:55PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Graham Motzing Graham Motzing 02/13/20 12:59PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Dirty30 Dillon Dirty30 Dillon 02/13/20 02:12PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:59PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:52PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:57PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/13/20 01:01PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Pushrod Fifty Pushrod Fifty 02/14/20 09:44AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Aaron Blair Aaron Blair 02/14/20 09:58AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/14/20 11:45AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: pat splat pat splat 02/14/20 01:53PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/14/20 06:10PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: pat splat pat splat 02/15/20 09:37AM
