Re: Static timing and points gap for 1940s 2 stoke, low compression engine - Zurcher
el pollo /
you are screwed up at the points. you have not set the ignition timing. I'm an old smoker but not a moped guy so we talk mm btdc instead of degrees. you need a multimeter to set static timing. when the points open the coil fires. you need to line up the timing marks and set the points gap so they open at your timing marks. the maxi is 17 degrees but I would make marks at 1.8mm btdc. that measurement is almost universal with 2t motorcycles. then I would static time with a meter.
very cool project. as far as I can see from your post you have done everything correctly except timing.
  Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherTopic by: kenneth Winter kenneth Winter 02/13/20 11:30AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Probably Fred Probably Fred 02/13/20 11:37AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/13/20 12:09PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Dirty30 Dillon Dirty30 Dillon 02/13/20 12:28PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:55PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Graham Motzing Graham Motzing 02/13/20 12:59PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Dirty30 Dillon Dirty30 Dillon 02/13/20 02:12PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:59PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:52PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:57PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/13/20 01:01PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Pushrod Fifty Pushrod Fifty 02/14/20 09:44AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Aaron Blair Aaron Blair 02/14/20 09:58AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/14/20 11:45AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: pat splat pat splat 02/14/20 01:53PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/14/20 06:10PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: pat splat pat splat 02/15/20 09:37AM
