Re: Static timing and points gap for 1940s 2 stoke, low compression engine - Zurcher
Probably Fred /
You need more then 10° before top center for most engines Try 20° And you could lower it more if it starts running hot
  Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherTopic by: kenneth Winter kenneth Winter 02/13/20 11:30AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Probably Fred Probably Fred 02/13/20 11:37AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/13/20 12:09PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Dirty30 Dillon Dirty30 Dillon 02/13/20 12:28PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:55PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Graham Motzing Graham Motzing 02/13/20 12:59PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Dirty30 Dillon Dirty30 Dillon 02/13/20 02:12PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:59PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:52PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:57PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/13/20 01:01PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Pushrod Fifty Pushrod Fifty 02/14/20 09:44AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Aaron Blair Aaron Blair 02/14/20 09:58AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/14/20 11:45AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: pat splat pat splat 02/14/20 01:53PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/14/20 06:10PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: pat splat pat splat 02/15/20 09:37AM
