Static timing and points gap for 1940s 2 stoke, low compression engine - Zurcher
kenneth Winter /
Engine - 1945ish Derny Cyclomoteur, Zurcher motor. 98cc.
I need input for setting the static timing for the COOL old engine..
I tried 10 degrees before TDC and a gap of .0015.. NOTHING.
Where to I Start to get it to Start??
What has been done:
Removed cylinder - deglazed bore.
Cleaned piston and ring lands. It had usually Larger rings ( 2)
Seal base gasket and head..
Rebuild carb
Added a buzz box coil to insure HOT SPARK... Good blue spark.
I put it on a stand.. .and it started and would run on choke... rev with throttle, backfire and die... ie would not take throttle..
THUS I figured improper timing..
I DID NOT mark the prior testing timing position (Dumb I know).
1. I found TDC with piston stop.
2. Marked (Keyed) fly wheel and head with TDC and added advance/retart marks for 20 degrees+-
3. Timing is set by clocking the distributor to gear reduction.. I set the timing to 10 degrees of advance...
4. Spin the motor with drill... nothing other than a single pop?
Now I dont know what to do..
  Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherTopic by: kenneth Winter kenneth Winter 02/13/20 11:30AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Probably Fred Probably Fred 02/13/20 11:37AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/13/20 12:09PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Dirty30 Dillon Dirty30 Dillon 02/13/20 12:28PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:55PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Graham Motzing Graham Motzing 02/13/20 12:59PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Dirty30 Dillon Dirty30 Dillon 02/13/20 02:12PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:59PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:52PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: kenneth Winter kenneth Winter 02/13/20 12:57PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/13/20 01:01PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Pushrod Fifty Pushrod Fifty 02/14/20 09:44AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: Aaron Blair Aaron Blair 02/14/20 09:58AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/14/20 11:45AM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: pat splat pat splat 02/14/20 01:53PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: el pollo el pollo 02/14/20 06:10PM
  Re: Static timing and points gap for 1940s 2 stoke, low compression engine - ZurcherRe: pat splat pat splat 02/15/20 09:37AM
