Re: Motron shock disassembly
Nathan Wizard /
I honestly think these shocks were not meant to come apart I played with min for an hour or so. a few nights ago
I got my rubber cap off the top and you can see both top and bottom the chrome bit is pressed down around the shock. Meaning I believe it’s assembled to be a one time thing. They put it all together then pinch it. Because even if I did “unthread” something inside, neither end could come out because the chime sleeve is folded down over top on both sides. I talked to my dad sho does the chrome and he says they are ganna try and run them through as one pice they just have to make sure they let it rinse extra long since some of the acid will most likely go up into the shock body during the process
