I don't even know if I should bother. I'm trolled by retards and when I tell someone on the ma to test something they cant.
how to test if your stator is blown. you need to disconnect the connector at the stator. you have 2 outputs. one goes to the headlight the other to the battery/tail. there should be continuity between the headlight and the battery/tail. if it is open then its burned out. you need to look at your manual to see what color wire is what.
