YSR50 electrical
BRIAN KAY /
Electrical help need
Ysr50 headlight doesn’t turn on with engine running . 6v system
1. Ok so I know that headlight isn’t controlled by the battery, it only turns on with motor running
2. With ignition key turned on,back running light ,brake light and front and rear turn signal work as well as horn .
3. Ran a test on headlight . Works with 6v source
Thinking it could possible be a bad lighting coil .
If I run a wire from the back running light to the headlight it works but would that kill my battery eventually.
  YSR50 electricalTopic by: BRIAN KAY BRIAN KAY 02/11/20 03:36PM
  Re: YSR50 electricalRe: P D P D 02/11/20 05:48PM
  Re: YSR50 electricalRe: el pollo el pollo 02/12/20 02:08PM
