Re: Sachs 505 c/d Debate
Ja'Far Rogers /
I just noticed something else, the carbs came in 12mm and 10mm sizes right? Well there's another difference inside the 12mm carbs. One of my engines has a 12mm carb works much like the Encarwi diaphragm carb, it doesn't require a needle pin to operate well.
I just picked up an identical 12mm square bing to clean it up and inside it uses a much longer throttle barrel (same width) and it uses a needle pin with 4 notches to adjust midthrottle fuel mix.
Numbers on the side are 85/12/101 A, i recognize these numbers on other Sachs engines so maybe the other Encarwi-styled square Bing is the weirdo one with no needle pin.
  Sachs 505 c/d DebateTopic by: andrewhed andrewhed 11/11/07 05:10PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/11/07 05:11PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/11/07 05:22PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/11/07 06:21PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/11/07 06:58PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/11/07 08:26PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/11/07 08:31PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/11/07 09:47PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/11/07 10:35PM
  Re: Sachs 505 c/d DebateRe: Ray West Ray West 11/11/07 10:46PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/11/07 11:13PM
  Re: Sachs 505 c/d DebateRe: Ray West Ray West 11/11/07 11:25PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/11/07 11:27PM
  Re: Sachs 505 c/d DebateRe: Erin L Erin L 11/12/07 12:12AM
  Re: Sachs 505 c/d DebateRe: Shalerrr rrr Shalerrr rrr 11/12/07 12:15AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 12:54AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 12:57AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 01:13AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 01:14AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 01:19AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 01:32AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 01:39AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 01:45AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 01:52AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 02:00AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 01:55AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:01AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 02:07AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:23AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 02:27AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:33AM
  Re: Sachs 505 c/d DebateRe: Roberto Roberto 11/12/07 02:32AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:46AM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 02:24PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 02:40AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:47AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 03:02AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 03:28AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 03:31AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 03:51AM
  Re: Sachs 505 c/d DebateRe: Roberto Roberto 11/12/07 03:51AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 07:53AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 09:26AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 12:15PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 12:16PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 12:23PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 12:36PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/12/07 12:46PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 12:46PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 12:48PM
  No KitRe: Chris Slamminson #116 Chris Slamminson #116 11/12/07 02:32PM
  No KitRe: Mike Bartell Mike Bartell 11/12/07 02:46PM
  Re: No KitRe: Clint Chilcott Clint Chilcott 11/12/07 06:43PM
  Re: No KitRe: Mike Bartell Mike Bartell 11/12/07 09:01PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 02:40PM
  Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 02:45PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 03:23PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 05:23PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 04:06PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 05:14PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 05:26PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 05:35PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 06:50PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:01PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 07:28PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 06:56PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:03PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 07:08PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:16PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 07:25PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:29PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 07:30PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 07:33PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:49PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 08:20PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 08:28PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/12/07 08:47PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 08:53PM
  Re: Sachs 505 c/d DebateRe: sullivan giles sullivan giles 11/12/07 11:52PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 08:51PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 08:54PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 08:54PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 08:59PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 09:43PM
  Re: No KitRe: Graham Motzing Graham Motzing 11/12/07 09:31PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 09:54PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 11:36PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/13/07 12:09AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/13/07 12:45AM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/13/07 12:48PM
  Re: Sachs 505 c/d DebateRe: Ray West Ray West 11/13/07 01:32PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/13/07 02:44PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/13/07 05:49PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/13/07 07:46PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/13/07 10:39PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/13/07 11:00PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/14/07 12:52AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/14/07 12:55AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/14/07 04:18AM
  Re: Sachs 505 c/d DebateRe: Brentus Sioux y Cycle Brentus Sioux y Cycle 11/26/07 11:14PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/26/07 11:34PM
  Re: Sachs 505 c/d DebateRe: Brentus Sioux y Cycle Brentus Sioux y Cycle 11/26/07 11:39PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/27/07 12:12AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/27/07 12:24AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/27/07 12:25AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/27/07 09:30AM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/27/07 01:12PM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 05/30/08 11:45AM
  Re: Sachs 505 c/d DebateRe: Erin L Erin L 05/30/08 03:37PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 05/30/08 04:05PM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 05/30/08 04:32PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 05/30/08 04:33PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 05/30/08 04:59PM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 05/30/08 05:46PM
  Re: Sachs 505 c/d DebateRe: Deadped Ryan Deadped Ryan 12/24/10 01:30AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 05/30/08 06:30PM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:49AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:52AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:54AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:55AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:58AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:59AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 05:01AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 05:03AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 05:10AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 12:50PM
  Re: Sachs 505 c/d DebateRe: B H B H 07/31/09 11:06AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 07/31/09 12:05PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 07/31/09 12:24PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 07/31/09 12:28PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 07/31/09 02:07PM
  Re: Sachs 505 c/d DebateRe: B H B H 07/31/09 02:24PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 07/31/09 02:32PM
  Re: Sachs 505 c/d DebateRe: Vlado vlado Vlado vlado 07/31/09 03:01PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 07/31/09 03:39PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 07/31/09 05:53PM
  Re: Sachs 505 c/d DebateRe: Vlado vlado Vlado vlado 07/31/09 10:36PM
  Re: Sachs 505 c/d DebateRe: nick nick 04/05/10 11:58PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 04/22/10 10:48PM
  Re: Sachs 505 c/d DebateRe: nick nick 04/06/10 12:00AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 04/06/10 12:11AM
  Re: Sachs 505 c/d DebateRe: gabriel Balaa gabriel Balaa 04/06/10 05:06AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 04/22/10 10:51PM
  Re: Sachs 505 c/d DebateRe: Born to be WillD Born to be WillD 11/02/10 04:39PM
  Re: Sachs 505 c/d DebateRe: Johnny 2stroke Johnny 2stroke 11/02/10 05:57PM
  Re: Sachs 505 c/d DebateRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 11/02/10 07:30PM
  Re: Sachs 505 c/d DebateRe: william hautenredi william hautenredi 12/24/10 05:02AM
  Re: Sachs 505 c/d DebateRe: Toledo Riot Toledo Riot 12/24/10 11:27AM
  Re: Sachs 505 c/d DebateRe: CtpEDsHED . CtpEDsHED . 12/24/10 11:47AM
  Re: Sachs 505 c/d DebateRe: Mike M Mike M 12/24/10 12:24PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 12/24/10 02:07PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 12/24/10 02:21PM
  Re: Sachs 505 c/d DebateRe: Deadped Ryan Deadped Ryan 12/24/10 02:59PM
  Re: Sachs 505 c/d DebateRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 12/24/10 04:26PM
  Re: Sachs 505 c/d DebateRe: Larry Picarello Larry Picarello 03/08/13 11:06PM
  Re: Sachs 505 c/d DebateRe: Deadped Ryan Deadped Ryan 03/08/13 11:38PM
  Re: Sachs 505 c/d DebateRe: Larry Picarello Larry Picarello 03/08/13 11:48PM
  Re: Sachs 505 c/d DebateRe: Ped Meister Ped Meister 03/09/13 09:34PM
  Re: Sachs 505 c/d DebateRe: Andrew Browning Andrew Browning 03/11/13 12:28PM
  Re: Sachs 505 c/d DebateRe: Born to be WillD Born to be WillD 03/11/13 02:36PM
  Re: Sachs 505 c/d DebateRe: Deadped Ryan Deadped Ryan 03/11/13 06:52PM
  Re: Sachs 505 c/d DebateRe: Andrew Browning Andrew Browning 03/11/13 03:21PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 06/11/20 01:53PM
  Re: Sachs 505 c/d DebateRe: Tim Doll Tim Doll 06/11/20 03:25PM
  Re: Sachs 505 c/d DebateRe: Born to be WillD Born to be WillD 06/11/20 05:38PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 06/11/20 11:08PM
  Re: Sachs 505 c/d DebateRe: Born to be WillD Born to be WillD 06/12/20 02:54PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 06/27/20 12:19AM
  Re: Sachs 505 c/d DebateRe: Will S Will S 06/27/20 08:25AM
