Re: Sachs 505 c/d Debate
Ja'Far Rogers /
Well from my experience there's not much difference between the 504's and the 505's except for the pedals no being inside the case.
You could file the head deck in the manner I suggested to Graham (0.25mm increments but no more than 1.5mm), you'd also need to retard your timing by several degrees (or millimetres on the stator plate). As long as you change both the cylinder and the piston you should be fine, however, the shorter crank may mean that the piston skirt could hit the crank bottom end at high rpms and that would really eff things up. Before you do any work at all check the piston skirt clearance and make sure you have at least 4mm clearance between the crank and the bottom of the skirt by cranking the flywheel.
  Sachs 505 c/d DebateTopic by: andrewhed andrewhed 11/11/07 05:10PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/11/07 05:11PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/11/07 05:22PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/11/07 06:21PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/11/07 06:58PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/11/07 08:26PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/11/07 08:31PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/11/07 09:47PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/11/07 10:35PM
  Re: Sachs 505 c/d DebateRe: Ray West Ray West 11/11/07 10:46PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/11/07 11:13PM
  Re: Sachs 505 c/d DebateRe: Ray West Ray West 11/11/07 11:25PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/11/07 11:27PM
  Re: Sachs 505 c/d DebateRe: Erin L Erin L 11/12/07 12:12AM
  Re: Sachs 505 c/d DebateRe: Shalerrr rrr Shalerrr rrr 11/12/07 12:15AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 12:54AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 12:57AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 01:13AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 01:14AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 01:19AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 01:32AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 01:39AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 01:45AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 01:52AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 02:00AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 01:55AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:01AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 02:07AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:23AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 02:27AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:33AM
  Re: Sachs 505 c/d DebateRe: Roberto Roberto 11/12/07 02:32AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:46AM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 02:24PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 02:40AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 02:47AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 03:02AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 03:28AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 03:31AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 03:51AM
  Re: Sachs 505 c/d DebateRe: Roberto Roberto 11/12/07 03:51AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 07:53AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 09:26AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 12:15PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 12:16PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 12:23PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 12:36PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/12/07 12:46PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 12:46PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 12:48PM
  No KitRe: Chris Slamminson #116 Chris Slamminson #116 11/12/07 02:32PM
  No KitRe: Mike Bartell Mike Bartell 11/12/07 02:46PM
  Re: No KitRe: Clint Chilcott Clint Chilcott 11/12/07 06:43PM
  Re: No KitRe: Mike Bartell Mike Bartell 11/12/07 09:01PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 02:40PM
  Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 02:45PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 03:23PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 05:23PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 04:06PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 05:14PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 05:26PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 05:35PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 06:50PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:01PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 07:28PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 06:56PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:03PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 07:08PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:16PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 07:25PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:29PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 07:30PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 07:33PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 07:49PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 08:20PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 08:28PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/12/07 08:47PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 08:53PM
  Re: Sachs 505 c/d DebateRe: sullivan giles sullivan giles 11/12/07 11:52PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 08:51PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/12/07 08:54PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 11/12/07 08:54PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 08:59PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/12/07 09:43PM
  Re: No KitRe: Graham Motzing Graham Motzing 11/12/07 09:31PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/12/07 09:54PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/12/07 11:36PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/13/07 12:09AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/13/07 12:45AM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/13/07 12:48PM
  Re: Sachs 505 c/d DebateRe: Ray West Ray West 11/13/07 01:32PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/13/07 02:44PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/13/07 05:49PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/13/07 07:46PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/13/07 10:39PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/13/07 11:00PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/14/07 12:52AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/14/07 12:55AM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 11/14/07 04:18AM
  Re: Sachs 505 c/d DebateRe: Brentus Sioux y Cycle Brentus Sioux y Cycle 11/26/07 11:14PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/26/07 11:34PM
  Re: Sachs 505 c/d DebateRe: Brentus Sioux y Cycle Brentus Sioux y Cycle 11/26/07 11:39PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/27/07 12:12AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 11/27/07 12:24AM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 11/27/07 12:25AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 11/27/07 09:30AM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 11/27/07 01:12PM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 05/30/08 11:45AM
  Re: Sachs 505 c/d DebateRe: Erin L Erin L 05/30/08 03:37PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 05/30/08 04:05PM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 05/30/08 04:32PM
  Re: Sachs 505 c/d DebateRe: Ja'Far Rogers Ja'Far Rogers 05/30/08 04:33PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 05/30/08 04:59PM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 05/30/08 05:46PM
  Re: Sachs 505 c/d DebateRe: Deadped Ryan Deadped Ryan 12/24/10 01:30AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 05/30/08 06:30PM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:49AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:52AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:54AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:55AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:58AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 04:59AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 05:01AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 05:03AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 05:10AM
  Re: Sachs 505 c/d DebateRe: Kyle Kyle 06/01/08 12:50PM
  Re: Sachs 505 c/d DebateRe: B H B H 07/31/09 11:06AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 07/31/09 12:05PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 07/31/09 12:24PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 07/31/09 12:28PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 07/31/09 02:07PM
  Re: Sachs 505 c/d DebateRe: B H B H 07/31/09 02:24PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 07/31/09 02:32PM
  Re: Sachs 505 c/d DebateRe: Vlado vlado Vlado vlado 07/31/09 03:01PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 07/31/09 03:39PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 07/31/09 05:53PM
  Re: Sachs 505 c/d DebateRe: Vlado vlado Vlado vlado 07/31/09 10:36PM
  Re: Sachs 505 c/d DebateRe: nick nick 04/05/10 11:58PM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 04/22/10 10:48PM
  Re: Sachs 505 c/d DebateRe: nick nick 04/06/10 12:00AM
  Re: Sachs 505 c/d DebateRe: andrewhed andrewhed 04/06/10 12:11AM
  Re: Sachs 505 c/d DebateRe: gabriel Balaa gabriel Balaa 04/06/10 05:06AM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 04/22/10 10:51PM
  Re: Sachs 505 c/d DebateRe: Born to be WillD Born to be WillD 11/02/10 04:39PM
  Re: Sachs 505 c/d DebateRe: Johnny 2stroke Johnny 2stroke 11/02/10 05:57PM
  Re: Sachs 505 c/d DebateRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 11/02/10 07:30PM
  Re: Sachs 505 c/d DebateRe: william hautenredi william hautenredi 12/24/10 05:02AM
  Re: Sachs 505 c/d DebateRe: Toledo Riot Toledo Riot 12/24/10 11:27AM
  Re: Sachs 505 c/d DebateRe: CtpEDsHED . CtpEDsHED . 12/24/10 11:47AM
  Re: Sachs 505 c/d DebateRe: Mike M Mike M 12/24/10 12:24PM
  Re: Sachs 505 c/d DebateRe: Robert Rosselit Robert Rosselit 12/24/10 02:07PM
  Re: Sachs 505 c/d DebateRe: Mike Bartell Mike Bartell 12/24/10 02:21PM
  Re: Sachs 505 c/d DebateRe: Deadped Ryan Deadped Ryan 12/24/10 02:59PM
  Re: Sachs 505 c/d DebateRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 12/24/10 04:26PM
  Re: Sachs 505 c/d DebateRe: Larry Picarello Larry Picarello 03/08/13 11:06PM
  Re: Sachs 505 c/d DebateRe: Deadped Ryan Deadped Ryan 03/08/13 11:38PM
  Re: Sachs 505 c/d DebateRe: Larry Picarello Larry Picarello 03/08/13 11:48PM
  Re: Sachs 505 c/d DebateRe: Ped Meister Ped Meister 03/09/13 09:34PM
  Re: Sachs 505 c/d DebateRe: Andrew Browning Andrew Browning 03/11/13 12:28PM
  Re: Sachs 505 c/d DebateRe: Born to be WillD Born to be WillD 03/11/13 02:36PM
  Re: Sachs 505 c/d DebateRe: Deadped Ryan Deadped Ryan 03/11/13 06:52PM
  Re: Sachs 505 c/d DebateRe: Andrew Browning Andrew Browning 03/11/13 03:21PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 06/11/20 01:53PM
  Re: Sachs 505 c/d DebateRe: Tim Doll Tim Doll 06/11/20 03:25PM
  Re: Sachs 505 c/d DebateRe: Born to be WillD Born to be WillD 06/11/20 05:38PM
  Re: Sachs 505 c/d DebateRe: Graham Motzing Graham Motzing 06/11/20 11:08PM
  Re: Sachs 505 c/d DebateRe: Born to be WillD Born to be WillD 06/12/20 02:54PM
  Re: Sachs 505 c/d DebateRe: Cpt. F. Cpt. F. 06/27/20 12:19AM
  Re: Sachs 505 c/d DebateRe: Will S Will S 06/27/20 08:25AM
