I have a 1979 motobecane mobylette 50v Are the stock engines a AV7 or AV10
AV7
AV7 has a piston port, AV10 feeds reeds to the case, quickest way to see. but everything we got in the US was av7
Thanks bud. Debating on rebuilding my engine or just buy a new one. Crank bearings are shot.
Are bearings as expensive as a 'new' motor that you'd have to go through anyway ?
outer bearings are cheap. crank bearings come in a kit. the kit has a new crank new bearings on both ends, washers and a new crank pin.
about 80$ you can get the crank pressed on ebay for 50$.
