Re: Who's timing advice should i trust? :)
Dirty30 Dillon /
The first two numbers are describing flywheel rotation timing (listed in mm as Puch flywheels are 360mm, so 1mm in rotation = one degree), the last describes timing via piston placement, a la a timing tool.
12mm is close to stock timing, while 17mm is more-so in line with a mild kit and pipe motor.
