Who's timing advice should i trust? :)
So im gonna adjust the timing on my puch maxi e50.
youtube says 17mm before TDC.
Some sites say around 12mm before TDC
And this is the wierd thing, here in denmark, a puch maxi experts club say 1.8 mm before TDC? Thats a pretty big difference from 17mm...
who shall i trust?...
Re: Who's timing advice should i trust? :)
Don't have Puch's, but if I did I would get the service manual and set to stock specs, if it is a stock bike. It's around, (the manual) maybe someone can link you to it.
Dirty30 Dillon /
The first two numbers are describing flywheel rotation timing (listed in mm as Puch flywheels are 360mm, so 1mm in rotation = one degree), the last describes timing via piston placement, a la a timing tool.
12mm is close to stock timing, while 17mm is more-so in line with a mild kit and pipe motor.
Carl Emil Bager /
Oh! Of course, now it all makes sense. Thanks for the help!
If you search “ Puch Timing” in the wiki tab, you’ll find a good write up.
