Hi all, I am new here so sorry if I post this in the wrong place.
I have a garelli Gary Uno and it's having the usual problems with rubber clutch, since I am from Bulgaria (eastern Europe) access to parts for these machines is hard and expensive. I am going to take off some material off the rubber on a lathe, but nowhere can I find dimensions of the clutch. So can someone who has one on the shelf help? I need the outer diameter of the rubber part while its assembled. The bell housing is 95,5 mm what clearance should it have to the rubber will also help.
Thanks for your time.
