> Den 23 Wrote:
> > Tim Doll Wrote:
> > I’m working on a Balboa 5051C motor . The repair manual says the
> timing
> > should be 2.5-3.0 mm before TDC, I think that’s 25-30 degrees because
> > the flywheel is 360 mm in diameter ,is this correct,am I thinking
> right
> Wait ...360mm converts to over 14 inches... for a flywheel?
Should be circumference, not diameter.
