Re: Yamaha QT50
Joe . /
> Tim Doll Wrote:
> I’m working on a Balboa 5051C motor . The repair manual says the timing
> should be 2.5-3.0 mm before TDC, I think that’s 25-30 degrees because
> the flywheel is 360 mm in diameter ,is this correct,am I thinking right
> ? Thanks
Coming from the motobecane world, a MM before TDC measurement is taken with a piston stop tool. with the tool in the sparkplug hole the piston is stopped at tdc with the tool, and then the tool is used to measure the downstroke distance before tdc. once at X.Xmm BTDC the tool and piston travel are locked, and the flywheel is adjusted just until the points open.
its great if you're a tuner i suppose and want to tinker with your timing but a total pain in the ass if you're unfamiliar with keywayless flywheels.
might be different on a balboa though idk
  Yamaha QT50Topic by: Tim Doll Tim Doll 01/10/20 10:45PM
  Re: Yamaha QT50Re: Stephen Keller Stephen Keller 01/10/20 11:49PM
  Re: Yamaha QT50Re: Tim Doll Tim Doll 01/11/20 12:19AM
  Re: Yamaha QT50Re: Bob Naske Bob Naske 01/11/20 05:58AM
  Re: Yamaha QT50Re: Bob Naske Bob Naske 01/11/20 06:15AM
  Re: Yamaha QT50Re: Tim Doll Tim Doll 01/11/20 08:02AM
  Re: Yamaha QT50Re: Pops Peds Pops Peds 01/11/20 02:25PM
  Re: Yamaha QT50Re: Tim Doll Tim Doll 01/11/20 04:04PM
  Re: Yamaha QT50Re: Pops Peds Pops Peds 01/11/20 06:53PM
  Re: Yamaha QT50Re: Tim Doll Tim Doll 01/11/20 07:17PM
  Re: Yamaha QT50Re: Pops Peds Pops Peds 01/11/20 07:24PM
  Re: Yamaha QT50Re: Tim Doll Tim Doll 01/11/20 08:11PM
  Re: Yamaha QT50Re: Joe . Joe . 01/13/20 07:41PM
  Re: Yamaha QT50Re: Den 23 Den 23 01/13/20 10:50PM
  Re: Yamaha QT50Re: Seth B Seth B 01/13/20 11:44PM
  Re: Yamaha QT50Re: Jack Rutherford Jack Rutherford 01/11/20 11:15PM
  Re: Yamaha QT50Re: Jack Rutherford Jack Rutherford 01/11/20 11:23PM
  Re: Yamaha QT50Re: Tim Doll Tim Doll 01/11/20 11:26PM
  Re: Yamaha QT50Re: Joe . Joe . 01/13/20 07:32PM
  Re: Yamaha QT50Re: Don Ohio Don Ohio 01/14/20 12:27AM
  Re: Yamaha QT50Re: Jack Rutherford Jack Rutherford 01/14/20 04:08PM
  Re: Yamaha QT50Re: Tim Doll Tim Doll 01/14/20 12:46AM
  Re: Yamaha QT50Re: Don Ohio Don Ohio 01/14/20 12:54AM
  eRe: Yamaha QT50Re: Tim Doll Tim Doll 01/14/20 07:43AM
  Re: eRe: Yamaha QT50Re: P D P D 01/14/20 09:58AM
  Re: Yamaha QT50Re: Pops Peds Pops Peds 01/14/20 06:39PM
  Re: Yamaha QT50Re: Von Zy Von Zy 01/14/20 06:58PM
  Re: Yamaha QT50Re: Bob Naske Bob Naske 01/15/20 03:00PM
  Re: Yamaha QT50Re: Tim Doll Tim Doll 01/15/20 03:14PM
  Re: Yamaha QT50Re: P D P D 01/15/20 05:27PM
