Re: Let's see your LED headlight conversions.
el pollo /
its not a matter of running 6 or 12 or 4v. yea you can run dual voltages if the led has a driver. (a driver is a voltage regulator.) leds last forever when run dc. dc means you need a cap. pulasting dc will blow led's too. simple theory e=ixr. as long as e is regulated properly than current is regulated.
there is an elecronic part that does not pass dc, it stores it like a battery. it also allows ac to short out to ground. ac passes through this device. its called a cap and you need one with led projects. always use the largest cap for cheap. size matters.
practical application of theory means a 12v led does not need a driver with a 12v regulator. a 6v led does not need a driver when the regulator is 6v. the cheapo bulbs last for years.
some led's come with internal driver electronics. these bulbs are expensive and the electronics usually suck because they are designed for e bikes that have a battery and not a magnito. this type of bulb is to be avoided.
since I studied ee I can do things dillon can't do. the 3aaa battery led projector works. its sick how little I spend on 3 aaa projects. all the 3aaa crap has a blinky board. click once twice or three times to toggle between blinky modes the board has no function for a moped and the electronics and will fry quickly. the solution is simple. bypass the blinky board by cutting the wires from the board to the led. then just use the led wires. found this one on ebay for 2 bucks. the 4v drver is a voltage regulator that previously had no moped function. the emitter follower regulator uses as much power as it regulates. no worry with low current led's. found this beauty by doing the ebay search "800lm headlight aaa" 2 bucks! this search worked too "1000LM 3Mode Q5 LED Zoomable Headlamp AAA Head Torch Protable Headlight"
blinky board cut out and testing for polarity.
projector attached to a bracket attached to the horn mount. bend bracket to adjust beam.
dramatic night pic
  Let's see your LED headlight conversions.Topic by: Cavailer 17 Cavailer 17 01/04/20 10:18AM
  Re: Let's see your LED headlight conversions.Re: P D P D 01/04/20 10:36AM
  Re: Let's see your LED headlight conversions.Re: . . . . 01/04/20 11:55AM
  Re: Let's see your LED headlight conversions.Re: - Joe - - Joe - 01/04/20 01:11PM
  Re: Let's see your LED headlight conversions.Re: Cavailer 17 Cavailer 17 01/04/20 04:10PM
  Re: Let's see your LED headlight conversions.Re: D dB D dB 01/29/20 12:00PM
  Re: Let's see your LED headlight conversions.Re: Cavailer 17 Cavailer 17 01/04/20 04:09PM
  Re: Let's see your LED headlight conversions.Re: Stephen Keller Stephen Keller 01/04/20 08:18PM
  Re: Let's see your LED headlight conversions.Re: . . . . 01/05/20 11:34AM
  Re: Let's see your LED headlight conversions.Re: Pushrod Fifty Pushrod Fifty 01/04/20 07:56PM
  Re: Let's see your LED headlight conversions.Re: Born to be WillD Born to be WillD 01/08/20 11:46AM
  Re: Let's see your LED headlight conversions.Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/08/20 08:23PM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/09/20 08:11AM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/10/20 10:41AM
  Re: Let's see your LED headlight conversions.Re: Cavailer 17 Cavailer 17 01/10/20 02:00PM
  Re: Let's see your LED headlight conversions.Re: Cavailer 17 Cavailer 17 01/07/20 11:53PM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/10/20 10:47AM
  Re: Let's see your LED headlight conversions.Re: Cavailer 17 Cavailer 17 01/07/20 11:58PM
  Re: Let's see your LED headlight conversions.Re: Andrew B Andrew B 01/08/20 08:26PM
  Re: Let's see your LED headlight conversions.Re: Don Ohio Don Ohio 01/11/20 01:30PM
  Re: Let's see your LED headlight conversions.Re: Born to be WillD Born to be WillD 01/08/20 11:45AM
  Re: Let's see your LED headlight conversions.Re: Kevin Bishop Kevin Bishop 01/11/20 12:46PM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/12/20 03:57PM
  Re: Let's see your LED headlight conversions.Re: ken gilbert ken gilbert 01/13/20 07:32AM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/13/20 08:35AM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/13/20 10:12AM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/13/20 10:58AM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/13/20 11:29AM
  Re: Let's see your LED headlight conversions.Re: ken gilbert ken gilbert 01/13/20 04:16PM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/12/20 08:27PM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/12/20 09:55AM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/13/20 11:49AM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/13/20 12:52PM
  Re: Let's see your LED headlight conversions.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/19/20 08:46AM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/24/20 06:26PM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/25/20 01:03AM
  Re: Let's see your LED headlight conversions.Re: ken gilbert ken gilbert 01/25/20 07:50AM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/25/20 09:47AM
  Re: Let's see your LED headlight conversions.Re: ken gilbert ken gilbert 01/26/20 11:49AM
  Re: Let's see your LED headlight conversions.Re: Cavailer 17 Cavailer 17 01/13/20 01:57PM
  Re: Let's see your LED headlight conversions.Re: Jack MT Goatheads MPC Jack MT Goatheads MPC 01/15/20 06:25PM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/16/20 09:31AM
  Re: Let's see your LED headlight conversions.Re: ken gilbert ken gilbert 01/16/20 03:50PM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/16/20 03:53PM
  Re: Let's see your LED headlight conversions.Re: Bad Cadillac™ Bad Cadillac™ 01/16/20 07:42PM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/17/20 07:52AM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/17/20 10:22AM
  Re: Let's see your LED headlight conversions.Re: josh n josh n 01/17/20 10:40AM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/17/20 10:29AM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/17/20 11:47AM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/17/20 12:09PM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/17/20 12:48PM
  Re: Let's see your LED headlight conversions.Re: Dirty30 Dillon Dirty30 Dillon 01/17/20 02:28PM
  Re: Let's see your LED headlight conversions.Re: Born to be WillD Born to be WillD 01/27/20 01:06PM
  Re: Let's see your LED headlight conversions.Re: Seth B Seth B 01/27/20 02:25PM
  Re: Let's see your LED headlight conversions.Re: josh n josh n 01/17/20 08:23AM
  Re: Let's see your LED headlight conversions.Re: josh n josh n 01/17/20 08:30AM
  Re: Let's see your LED headlight conversions.Re: Diana Carrat Diana Carrat 01/17/20 12:29PM
  Re: Let's see your LED headlight conversions.Re: Pushrod Fifty Pushrod Fifty 01/25/20 08:09PM
  Re: Let's see your LED headlight conversions.Re: P D P D 01/25/20 09:46PM
  Re: Let's see your LED headlight conversions.Re: Seth B Seth B 01/25/20 10:33PM
  Re: Let's see your LED headlight conversions.Re: Pushrod Fifty Pushrod Fifty 01/26/20 08:17AM
  Re: Let's see your LED headlight conversions.Re: P D P D 01/26/20 09:28AM
  Re: Let's see your LED headlight conversions.Re: Alan Jackson Alan Jackson 01/26/20 12:13PM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 01/26/20 05:08PM
  Re: Let's see your LED headlight conversions.Re: Pushrod Fifty Pushrod Fifty 01/26/20 07:51PM
  Re: Let's see your LED headlight conversions.Re: Pushrod Fifty Pushrod Fifty 01/27/20 08:17AM
  Re: Let's see your LED headlight conversions.Re: Alan Jackson Alan Jackson 01/27/20 08:38AM
  Re: Let's see your LED headlight conversions.Re: Pushrod Fifty Pushrod Fifty 01/27/20 08:45AM
  Re: Let's see your LED headlight conversions.Re: Alan Jackson Alan Jackson 01/28/20 12:45PM
  Re: Let's see your LED headlight conversions.Re: Steven S Steven S 01/28/20 04:25AM
  Re: Let's see your LED headlight conversions.Re: Pushrod Fifty Pushrod Fifty 02/05/20 11:41AM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 02/05/20 12:10PM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 02/05/20 12:33PM
  Re: Let's see your LED headlight conversions.Re: Pushrod Fifty Pushrod Fifty 02/05/20 01:57PM
  Re: Let's see your LED headlight conversions.Re: el pollo el pollo 02/05/20 03:58PM
