Re: 70cc Puch Maxi top end?
Seth B /
Man, I don’t get it. You should be doing way better than 35. I can get better than that with a stock top end, pipe, and carb, with stock gears, just by changing the air filter and tuning the carburetor. You should be low-mid forties easy, even with the Proma. It’s not a high revving pipe, only about 8,000 rpm’s, but still. I can’t figure out what you’re doing wrong.
I do think you’re a bit optimistic in your expectations, but it should be performing better than it is. You are definitely over clutched. Two shoe, with kickstart springs is my go-to for stock and mid performance builds. If you were closer, I’d give you a hand with it.
One more thing; you have a clone carb. The carb body is fine, but have you changed to genuine Bing atomizer & slide? Make sure you’re using good internals, because the clones are tough to tune unless you replace the guts. I see you said it’s a 2.17, I don’t know if a 2.22 would help, but you might try it.
Your timing is at 17* you said. That’s okay if you’re stock, but I’d rather see it around 14-15. But to do that, you’ll have to file/dremel the mounting screw slots in order to rotate the stator plate far enough. You’re gaining on it. Keep at it, you’ll get there. Just remember, small adjustments make big differences with an engine this small, due to the small volumes of fuel and air it consumes.
  70cc Puch Maxi top end?Topic by: Kyle Washburn Kyle Washburn 12/31/19 01:50PM
  Re: 70cc Puch Maxi top end?Re: Probably Fred Probably Fred 12/31/19 03:46PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/01/20 06:26PM
  Re: 70cc Puch Maxi top end?Re: Probably Fred Probably Fred 01/01/20 06:54PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/02/20 07:23AM
  Re: 70cc Puch Maxi top end?Re: Seth B Seth B 01/02/20 02:14PM
  Re: 70cc Puch Maxi top end?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 02:26PM
  Re: 70cc Puch Maxi top end?Re: Dirty30 Dillon Dirty30 Dillon 12/31/19 08:55PM
  Re: 70cc Puch Maxi top end?Re: Jeff Parr Jeff Parr 12/31/19 10:05PM
  Re: 70cc Puch Maxi top end?Re: Jeff Parr Jeff Parr 12/31/19 11:22PM
  Re: 70cc Puch Maxi top end?Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/01/20 06:57PM
  Re: 70cc Puch Maxi top end?Re: The Dude The Dude 01/02/20 02:28PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/02/20 03:05PM
  Re: 70cc Puch Maxi top end?Re: Seth B Seth B 01/02/20 03:21PM
  Re: 70cc Puch Maxi top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/02/20 03:19PM
  Re: 70cc Puch Maxi top end?Re: Seth B Seth B 01/02/20 03:28PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/02/20 03:33PM
  Re: 70cc Puch Maxi top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/02/20 04:02PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/02/20 04:11PM
  Re: 70cc Puch Maxi top end?Re: Probably Fred Probably Fred 01/02/20 05:30PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/02/20 05:51PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/03/20 09:35PM
  Re: 70cc Puch Maxi top end?Re: P D P D 01/04/20 09:03AM
  Re: 70cc Puch Maxi top end?Re: Seth B Seth B 01/04/20 01:48PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/04/20 10:09AM
  Re: 70cc Puch Maxi top end?Re: P D P D 01/04/20 10:33AM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/05/20 02:17PM
  Re: 70cc Puch Maxi top end?Re: Seth B Seth B 01/05/20 03:16PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/05/20 07:15PM
  Re: 70cc Puch Maxi top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/05/20 08:31PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/05/20 10:01PM
  Re: 70cc Puch Maxi top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/06/20 07:12AM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/06/20 11:49AM
  Re: 70cc Puch Maxi top end?Re: P D P D 01/06/20 11:53AM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/06/20 12:03PM
  Re: 70cc Puch Maxi top end?Re: P D P D 01/06/20 12:41PM
  Re: 70cc Puch Maxi top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/06/20 12:54PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/06/20 01:05PM
  Re: 70cc Puch Maxi top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/06/20 06:35PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/06/20 01:00PM
  Re: 70cc Puch Maxi top end?Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/06/20 07:46AM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/06/20 12:00PM
  Re: 70cc Puch Maxi top end?Re: Dusty Rim Dusty Rim 01/06/20 06:45PM
  Re: 70cc Puch Maxi top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/06/20 06:48PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/06/20 10:35PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/07/20 11:21PM
  Re: 70cc Puch Maxi top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/07/20 11:26PM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/07/20 11:36PM
  Re: 70cc Puch Maxi top end?Re: Seth B Seth B 01/08/20 01:09AM
  Re: 70cc Puch Maxi top end?Re: Kenneth Hill Kenneth Hill 01/08/20 07:18AM
  Re: 70cc Puch Maxi top end?Re: Kyle Washburn Kyle Washburn 01/08/20 11:47AM
