Re: Scared to go a long trip. What should I bring?
Totally normal JBOT /
If you prepare the bike well and you'll need nothing.
Meaning less than 10yr old seals, paper fuel filter in front of carb, fresh oil in the gearbox,
1. Keep temps as low as possible with wc head. Can't say how many times people have air leaks and seize. With wc heads you can have an air leak and have plenty of time to figure out your issue without seizing
2. Use a normal oil mix, 32:1 or 50:1 or something.
3. Carry and extra one of everything so you won't need it.
Tubes, pullers, extra clutch, sockets, extra belt, Cdi or points/condenser plus chain strap vice grip wrench to undo rear pulley and variator nut/clutch bell nut, flywheel nut. Bolts, bailing wire, oil duh
On pinball I only had one seize from the miles on the kit, wore it out. (But it was my first ever kit)
I brought an extra kit and mounted it up and we were off.
Don't be afraid, it's the most thrilling thing ever to be traveling by mopeds long distances.
Oh, a phone or gps is cool to have mounted, along with a 12v out for phone charging as you ride.
Downhill Harvey (OFMC) /
Bring a chase vehicle, so you don't have to ride with all that crap.
Yeah bring your mother so you can suck some milk titties and she can change your diaper
Planning on doing some spring ped/camping trips with my buddy. Gonna try to cruise and not push the engine hard and take backroads to avoid all the idiots. Should be a blast and I look forward to maybe some pics of your trip. Good luck! Speaking from myself driving an old vw across the us, take a friend on another ped, usually helps if there's a break down and everyone takes a few parts, tools, and know how.
Bring a 5th of whiskey and a massage therapist if u can fit.
♣Slew Foot♣ /
Rabbits foot and a completely overhauled bike common one like a puch or TOMOS.
A cell phone cash.
♣Slew Foot♣ /
AAA recreation vehicle. Plan.
Regular AAA doesn't work for mopeds BTW.
Tri-ped Dave O.D.B. /
I rode from NY to Key West and back one Summer in the 1970s. Aside from my camping gear and snacks, I only brought a small tool box and a spark plug. Back then, every bicycle shop sold mopeds, so I bought anything I needed on the road. Try that today. There were four of us and it was the best Summer of my college years.
the 5th of whiskey is a good call, if you do break down and can't fix it, it keeps you entertained while you wait for help
Not a bad ideaR to bring along a teddy bear and wubbie case u reaLLLY get skerT.
♣Slew Foot♣ /
Top shelf insurance you know full boat so that if you do break down you'll get a rental to finish it
A power-Station and a Navigation system
this has never been thought of, and its never gone wrong
Prolly shud get a bowl of popcorn an attrach it to the hamdlebars for a snack.
Condoms and lots of them.
He doesn't live in France...
> snack.
And a USB powered microwave to cook it! Dont forget your butter seasoning!
Bring as much fuel as u can fit!!
Make sure u do some sit ups so u can sit up.
Bring a parachute case tha brakes go out.
Roger Suarez /
Just got back from a major break down 4 miles from home. Bearing gave out and took out my piston crown and squished the piston ring. Had to load her on back of a pick up truck.
Now really having second thoughts lol (edited)
Lack of lubrication?
Definition of a hobby!
Dang yeah If that's the stage 6 setup yeah that bearing can bounce back and forth like 15mm along the wrist pin. lubrication was "probably" fine. It rattled/sideloaded itself to bits. The devil is in the details. Try a wider higher quality bearing next go at it.
