Upping wheel size on Honda Express Nx50
Isaiah Lewis /
Can you up the wheel size from 10” to the 14” wheel on the 1981 Honda Express Sr Nx50?
Re: Upping wheel size on Honda Express Nx50
Terbo Speghetti /
Yes and no. The splines fit, but there's a lip on the larger rim that keeps it from mating fully. You've gotta either grind down your case, or grind down there lip on the wheel.
If you do the case, be careful not to blow through to your gearbox while you're grinding
