Re: What is the proper way of lowering EBR Forks?
Jesse Simonsen /
> Graham Motzing Wrote:
> The easiest way to lower them is to cut down the big spring and add a
> spacer behind the rebound spring but to will lose travel, works for
> adapting dirtbike forks with tons of travel but not so good on short
> travel street forks.
> Otherwise you gotta cut the tube down which requires a lathe to rethread
> the end
I just watched a YouTube video of a machinist cutting and rethreading some ts185(?) forks and it looked like a lot of work to lower forks 1 1/4". Must've cost the customer a bunch of money.
