Re: What is the proper way of lowering EBR Forks?
Graham Motzing /
The easiest way to lower them is to cut down the big spring and add a spacer behind the rebound spring but to will lose travel, works for adapting dirtbike forks with tons of travel but not so good on short travel street forks.
Otherwise you gotta cut the tube down which requires a lathe to rethread the end
