Corrosion
Got this 13:13 carb as an extra in buy. Looked funky but the body cleaned ok. Then I opened it up, bummer. I think it looks worse than it is. Inside the tube is clean. Should i solder & sand it? Or go as is? Or go get a new one? I took pics but they look like shit.
Re: Corrosion
Here’s a pic
Re: Corrosion
As long as the threads and sealing surfaces are ok just go ahead and use it.
Re: Corrosion
Yes, they are I removed the jet after I let it soaked. Weather here is nice in Ohio, so I can finish Monday maybe.
Re: Corrosion
> it.
Agreed^ .
That looks a lot like the insides of the carb on my FA50 , which runs very well .
Re: Corrosion
doesnt look like a 13sha to meee
Re: Corrosion
I've been working with muriatic acid to clean up a lot of the rotten parts on my latest build. its gone pretty damn well so far except for a few parts that just seem to be very delicate metal.
odd how it ate up the petcock body but not the knob.
With carbs, a long as the slide operates smoothly, all the passages are clear with compressed air, float functions, and like stated, it seals, its worth giving it a try. but to be honest with how hilariously cheap clone carbs are its almost not worth the hassle. most headaches i've ever had from old carbs were float issues.
Re: Corrosion
I can double check ... I’ll post a pic. ;)
Re: Corrosion
Dirty30 Dillon /
I ditto that statement
Re: Corrosion
Soak that part in Evaporust and it will look like new .I was a doubter at one time but after using it I’m a believer . $25 a gallon and worth it’s weight in gold.
