Re: Starting bid 2600$
Overpriced Parts /
> Dirty30 Dillon Wrote:
> > P D Wrote:
> > Is what Ken said true or not ?
> Ken's assumption that the deciding factor concerning a moped's worth is
> it's carrying capacity, or general specs at all, is false. If that were
> the case than the best moped is an S10 pickup because it can go 65
> safely and can hold over 500 pounds of cargo in addition to the
> "riders."
> Is it true that the Cobra is just a cross-barred step-through frame with
> springer forks? Yes.
> Ken is losing touch.
No all I’m saying is the bike is not worth more than a magnum because a magnum is all around bigge, heavier duty bike which makes it way safer and better,
I don’t know what puch was thinking by putting tiny maxi forks, maxi swing arm and shocks on top tank bike making it a cheep construction of a magnum and they knew they blew it so they put the weight restrictions on it,
I had a several cobras go through my hands including 2 white ones, most were bent as a pretzel from one or two minor Downing’s/accidents and had to be parted out, luckily I got to keep two black Side cover needle bearing crank Za50s white cobra engines which are the best puch automatic engines and actually I got one on a bike and it’s about the fastest given the same kit over other years za50s
Cobras are cool bikes but they don’t demand that nuts price, not even a white one
if someone sells a stock magnum for $2,600 starting bid it be attacked just as much,
  Starting bid 2600$Topic by: Road Kill Road Kill 12/10/19 11:49AM
  Re: Starting bid 2600$Re: P D P D 12/10/19 12:14PM
  Re: Starting bid 2600$Re: Jimmy Cincinnati Jimmy Cincinnati 12/10/19 12:17PM
  Re: Starting bid 2600$Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 12:20PM
  Re: Starting bid 2600$Re: Overpriced Parts Overpriced Parts 12/10/19 12:30PM
  Re: Starting bid 2600$Re: Dirty30 Dillon Dirty30 Dillon 12/10/19 12:41PM
  Re: Starting bid 2600$Re: P D P D 12/10/19 12:45PM
  Re: Starting bid 2600$Re: * * * * 12/10/19 03:44PM
  Re: Starting bid 2600$Re: Dirty30 Dillon Dirty30 Dillon 12/10/19 04:05PM
  Re: Starting bid 2600$Re: Overpriced Parts Overpriced Parts 12/10/19 04:33PM
  Re: Starting bid 2600$Re: Dirty30 Dillon Dirty30 Dillon 12/10/19 04:36PM
  Re: Starting bid 2600$Re: live ɘvil live ɘvil 12/10/19 05:37PM
  Re: Starting bid 2600$Re: Boot 2Thehead Boot 2Thehead 12/10/19 09:38PM
  Re: Starting bid 2600$Re: Guthrie Mass Guthrie Mass 12/10/19 09:59PM
  Re: Starting bid 2600$Re: * * * * 12/10/19 09:59PM
  Re: Starting bid 2600$Re: live ɘvil live ɘvil 12/12/19 01:36AM
  Re: Starting bid 2600$Re: Daniel '' Daniel '' 12/13/19 11:18PM
  Re: Starting bid 2600$Re: Moped Lar (OFMC) Moped Lar (OFMC) 12/10/19 12:49PM
  Re: Starting bid 2600$Re: Graham Motzing Graham Motzing 12/10/19 01:04PM
  Re: Starting bid 2600$Re: Potr zebie Potr zebie 12/10/19 01:16PM
  Re: Starting bid 2600$Re: Jason Thompson Jason Thompson 12/15/19 02:44AM
  Re: Starting bid 2600$Re: Stephen Keller Stephen Keller 12/10/19 01:21PM
  Re: Starting bid 2600$Re: Trent Anderson Trent Anderson 12/10/19 02:43PM
  Re: Starting bid 2600$Re: Jonathan R Jonathan R 12/12/19 01:09PM
  Re: Starting bid 2600$Re: live ɘvil live ɘvil 12/13/19 02:07PM
  Re: Starting bid 2600$Re: Overpriced Parts Overpriced Parts 12/13/19 04:42PM
  Re: Starting bid 2600$Re: Double Trouble Dan Double Trouble Dan 12/13/19 06:26PM
