Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?
Trent Anderson /
Picked this up a few months ago. It's a Garellibela.
Huh?
A previous owner took a Garelli front end and hacked on a Carabela rear end. The thing came with a tote full of parts, looking like 3 Garelli engines in states of disrepair, no extra carburators, some fenders, 2 Garelli tanks and swing arms, the original foot rest and 3 chain guards, the Carabela engine, swing arm, chain guard, and more.
Here's what all I discovered:
The Garelli petcock broke, so he slapped on a Carabela tank and petcock, bolting it at a single point THROUGH one of the holes in the spark plug coil.
At some point, the engine must have died, so he removed the Garelli engine and decided to try the Carabela, a Mexican, Minarelli clone with some but not all interchangeable Minarelli parts.
The Minarelli chain is on the left, and the Garelli on the right, so the swing arm had to be swapped to accommodate the brake and chain. As the chains are the same gauge, he just flipped the wheel upside down/backwards.
However the chain would hit the frame or swing arm, so the engine AND the shocks needed to be lowered or extended. The engine by just a couple inches, the shocks by 8 inches.
The bars added to the shocks are only connected by one bolt, so any large bump at any speed would probably fold up and cause a wreck.
I would also think that he would have had to get a longer chain, but I didn't see any EXTRA master links, however, I did see a half link.
Minarelli engines often have a ceramic resistor in the tail light that grounds when you hit the brake, preventing stalling. If you don't have the resistor, you can always just pull the wires to the brake light micro switches and connect them, making your brake lights either on all the time or off all the time, I can't remember.
With the rear wheel sitting 8 inches lower, the kickstand wasn't long enough, so he pulled one from another bike AND added another 1.5 inches to it. Since the spring didn't line up on the new kickstand, I think it goes up the center, he grabbed a rubber bungee cord, hooked one end to the luggage rack, the other to a newly drilled hole on his kickstand extension piece, then added a zip tie to make sure it didn't fall off the kickstand.
Since the rear wheel was moved back an inch or so, the fender would rub the wheel, so he moved the fender back by adding a metal concrete lag screw tap? and a 2 inch bolt.
Finally, instead of using the kill switch on the handlebar, (it's possible that it's bad) he connected a toggle switch to one of the wires from the engine and ran it to one of the wires in the tail light.
A wiring diagram for Garelli's suggest 3 wires going to the tail light, but the wire under the fender only has 2, plus his extra toggle switch wire.
Finally, it's got a Jawa seat and the exhaust bracket is missing
I'm just amazed that that the guy I got it from and the guy that made all the modifications kept the footrest, chain guards, gas tank, and swing arm. As usual, "it ran when parked!"
I had some tires, tubes, and a Tractor Supply tail light lying around, then bought about $20 worth of nuts and bolts at the hardware store and have been putting it back proper this week. It's still going to need a petcock, tail light wires, the bracket that holds the headlight switch onto the handlebar, chain, and, of course, the entire powerplant. I have a Batavus parts bike in my shed and I'm going remove it's kickstand, as I noticed that it's spring goes up the center and it's still there.
  What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Topic by: Ashley Ashley Ashley Ashley 12/02/19 02:18PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: live ɘvil live ɘvil 12/02/19 02:31PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Trent Anderson Trent Anderson 12/02/19 04:24PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: alex . alex . 12/02/19 05:48PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: live ɘvil live ɘvil 12/03/19 03:13AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Trent Anderson Trent Anderson 12/02/19 07:08PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Captain Janeway Captain Janeway 12/02/19 08:52PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Joe Schuitema Joe Schuitema 12/02/19 10:26PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Captain Janeway Captain Janeway 12/03/19 10:26AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: P D P D 12/03/19 12:06PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Dirty30 Dillon Dirty30 Dillon 12/03/19 12:08PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/03/19 12:48PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: ken gilbert ken gilbert 12/03/19 01:14PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Captain Janeway Captain Janeway 12/03/19 01:22PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: ♣Slew Foot♣ ♣Slew Foot♣ 12/03/19 04:35AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/03/19 11:01AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Born to be WillD Born to be WillD 12/05/19 02:15PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Chris Szuba Chris Szuba 12/03/19 11:04AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: MPB Andyrew MPB Andyrew 12/03/19 02:14PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Stephen Keller Stephen Keller 12/03/19 02:16PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Dirty30 Dillon Dirty30 Dillon 12/03/19 02:21PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Daniel '' Daniel '' 12/03/19 08:05PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Adam Strait Adam Strait 12/06/19 10:01PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Seth B Seth B 12/06/19 11:13PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Stephen Keller Stephen Keller 12/04/19 04:02PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: scrot rash scrot rash 12/05/19 07:18AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: scrot rash scrot rash 12/05/19 07:33AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: EH FCC of the QCB EH FCC of the QCB 12/05/19 10:41PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Drew Cooper Drew Cooper 12/06/19 10:22AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Bas Autowas Bas Autowas 12/05/19 09:22AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: scrot rash scrot rash 12/05/19 09:48AM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: sean t sean t 12/06/19 12:58PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: Stephen Keller Stephen Keller 12/06/19 01:22PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: live ɘvil live ɘvil 12/06/19 10:44PM
  Re: What's the crappiest/scariest/hokiest/dangerousest mod/fix you have ever seen?Re: scrot rash scrot rash 12/07/19 02:42AM
