Re: 1977 garelli gran sport handlebar stem removal
Bas Autowas /
> live ɘvil Wrote:
> Usually what I do when
> taking these apart is loosen the center bolt you removed a few turns
> then promptly smack the head with a hammer to unwedge before removing
> the entire assembly with bars as a unit.
This is how you do it
Try to get the center bolt in pretty tight so its grabbing the clamp on the inside. (But still loose enough to get it loose when you're whacking it.
