Re: 1981 Motocompo Build
will warn /
Older vespa scooters run 8in tire so I'm sure you'll find something. I would just leave the brakes stock your not going to need much more than what it came with in reality. Figure those same pads are on Hondas with much larger wheels. As the size of the wheel increases the breaking effectiveness decreases the opposite as wheel size decreases the brakes are more effective. There is an abundance of info on wheel size and braking all over the internet for cars and bikes a like.
> Pritza R&D Wrote:
> Great info! I’ve been looking into monkey wheels and machining my own
> rear adaptor to go from spline to 4 bolt. I want to at least get a rear
> disk on it with possibly a bearing support on the right.
> I was at a loss for forks. I see all these Japan dudes with super cool
> forks but couldn’t find them anywhere. So thank yuh for this knowledge.
> I’m pretty hard set on still running 8in wheels because I think 10s
> throw the proportions off and it looks really dumb and donked out. There
> are a lot of nice monkey 8 in wheels around
> > Cesar E Wrote:
> > This Motocompo will need attention to the front-end.
> > The factory fork and brake reach their abilities even with original
> > engine specs, factory "bearing" in the steering head is worn out
> easily.
> > Some 10" Scoot-Forks (Macal, Malaguti) could deliver a stabilized
> front.
> > 10" Wheels with greater drum brakes are in Honda Elite/Spacy 250
> > scooters i.e.
> > Great to see this!
> > I have no knowledge of a 8" Rim with a bigger brake drum...Maybe in
> the
> > Monkey, Gorilla, Dax-Scenery?
  1981 Motocompo BuildTopic by: Pritza R&D Pritza R&D 11/27/19 12:17PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 11/27/19 12:24PM
  Re: 1981 Motocompo BuildRe: Cavailer 17 Cavailer 17 01/04/20 04:18PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 11/27/19 12:27PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 11/27/19 12:34PM
  Re: 1981 Motocompo BuildRe: Terbo Speghetti Terbo Speghetti 11/27/19 12:45PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 11/27/19 12:47PM
  Re: 1981 Motocompo BuildRe: Dickie Thompson Dickie Thompson 11/27/19 01:09PM
  Re: 1981 Motocompo BuildRe: Cameron Cate Cameron Cate 11/27/19 05:02PM
  Re: 1981 Motocompo BuildRe: Stephen Keller Stephen Keller 11/27/19 01:11PM
  Re: 1981 Motocompo BuildRe: Eddie Bravo Eddie Bravo 11/27/19 01:16PM
  Re: 1981 Motocompo BuildRe: EH FCC of the QCB EH FCC of the QCB 11/27/19 02:26PM
  Re: 1981 Motocompo BuildRe: Andrew Sobel Andrew Sobel 11/27/19 08:34PM
  Re: 1981 Motocompo BuildRe: Guthrie Mass Guthrie Mass 11/27/19 09:21PM
  Re: 1981 Motocompo BuildRe: Dan (high idle) Conway Dan (high idle) Conway 11/27/19 09:35PM
  Re: 1981 Motocompo BuildRe: Alex hernandez Alex hernandez 11/28/19 12:16AM
  Re: 1981 Motocompo BuildRe: Nick / Ratbone Nick / Ratbone 11/28/19 05:44AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 12/04/19 02:35PM
  Re: 1981 Motocompo BuildRe: Stephen Keller Stephen Keller 12/04/19 02:42PM
  Re: 1981 Motocompo BuildRe: Chris Szuba Chris Szuba 12/05/19 12:00PM
  Re: 1981 Motocompo BuildRe: sean t sean t 12/05/19 01:28PM
  Re: 1981 Motocompo BuildRe: Born to be WillD Born to be WillD 12/05/19 01:36PM
  Re: 1981 Motocompo BuildRe: Alexandro Ramirez-Nagy Alexandro Ramirez-Nagy 12/06/19 12:01PM
  Re: 1981 Motocompo BuildRe: live ɘvil live ɘvil 12/07/19 04:56PM
  Re: 1981 Motocompo BuildRe: L ee L ee 12/09/19 12:23PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 12/23/19 09:01AM
  Re: 1981 Motocompo BuildRe: Bas Autowas Bas Autowas 12/23/19 09:14AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 12/23/19 09:05AM
  Re: 1981 Motocompo BuildRe: Dead Possum Dead Possum 12/23/19 09:09AM
  Re: 1981 Motocompo BuildRe: kevin smellaflange kevin smellaflange 12/25/19 10:08PM
  Re: 1981 Motocompo BuildRe: Trent Anderson Trent Anderson 12/26/19 04:36AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/02/20 10:05AM
  Re: 1981 Motocompo BuildRe: Ryan Go Ryan Go 01/02/20 10:43AM
  Re: 1981 Motocompo BuildRe: Brad Cat Brad Cat 01/09/20 08:26PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/16/20 03:37PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/16/20 05:31PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/16/20 08:54PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/16/20 09:51PM
  Re: 1981 Motocompo BuildRe: Daniel '' Daniel '' 01/16/20 09:25PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/17/20 04:14PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/16/20 08:58PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/16/20 09:02PM
  Re: 1981 Motocompo BuildRe: Cesar E Cesar E 01/16/20 09:48PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/17/20 04:12PM
  Re: 1981 Motocompo BuildRe: Dirty30 Dillon Dirty30 Dillon 01/17/20 04:24PM
  Re: 1981 Motocompo BuildRe: will warn will warn 01/18/20 12:44PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/18/20 12:53PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/18/20 02:04PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/18/20 02:40PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/18/20 02:06PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/18/20 02:51PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/20/20 09:21PM
  Re: 1981 Motocompo BuildRe: ID OD ID OD 01/23/20 05:09AM
  Re: 1981 Motocompo BuildRe: DJLou Magnetos ($M$) DJLou Magnetos ($M$) 01/23/20 02:04PM
  Re: 1981 Motocompo BuildRe: Alex hernandez Alex hernandez 01/23/20 04:05PM
  Re: 1981 Motocompo BuildRe: Eddie Bravo Eddie Bravo 01/23/20 03:03PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/23/20 03:33PM
  Re: 1981 Motocompo BuildRe: Ty 🏍 Ty 🏍 01/23/20 03:18PM
  Re: 1981 Motocompo BuildRe: Eddie Bravo Eddie Bravo 01/23/20 03:44PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/30/20 11:23AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/30/20 11:28AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/09/20 01:00PM
  Re: 1981 Motocompo BuildRe: Chris Szuba Chris Szuba 03/09/20 01:32PM
  Re: 1981 Motocompo BuildRe: Brandon Love Brandon Love 03/09/20 03:17PM
  Re: 1981 Motocompo BuildRe: Nile A Nile A 03/12/20 04:05AM
  Re: 1981 Motocompo BuildRe: RingringBANG ! RingringBANG ! 03/15/20 07:50PM
  Re: 1981 Motocompo BuildRe: active16bits . active16bits . 03/22/20 10:38AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/23/20 11:03AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/25/20 06:53AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/25/20 06:55AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/30/20 12:05PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/30/20 12:06PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/30/20 12:08PM
  Re: 1981 Motocompo BuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/30/20 12:21PM
  Re: 1981 Motocompo BuildRe: Luke W Luke W 05/06/20 01:17PM
  Re: 1981 Motocompo BuildRe: Ryan Graeme Ryan Graeme 05/06/20 02:21PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 04/21/20 07:56AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 04/21/20 08:04AM
  Re: 1981 Motocompo BuildRe: Dan (high idle) Conway Dan (high idle) Conway 04/22/20 10:08AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 04/28/20 07:04AM
  Re: 1981 Motocompo BuildRe: Jay Rivett Jay Rivett 04/28/20 11:00AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 04/29/20 08:51AM
  Re: 1981 Motocompo BuildRe: Jack Farley Jack Farley 04/30/20 09:35PM
  Re: 1981 Motocompo BuildRe: Jake P Jake P 05/01/20 10:53AM
  Re: 1981 Motocompo BuildRe: ◕ ‿ ◕ ◕ ‿ ◕ 05/01/20 12:31PM
  Re: 1981 Motocompo BuildRe: will warn will warn 05/02/20 02:55PM
  Re: 1981 Motocompo BuildRe: Trent Anderson Trent Anderson 05/02/20 03:08PM
