Which Puch kits work well with stock pipe
Angry Hipster /
Obviously stock, but they seem difficult to find in good shape. Is there an aftermarket option available that I'm missing? Thanks.
Re: Which Puch kits work well with stock pipe
Dirty30 Dillon /
The re-popped alu Metrakit works great with a stock pipe.
I have some zeta made stock replicas if that's really all you're going after.
The small Airsal isnt bad either.
With a stock pipe performance will always be pretty bad, so i'd say any 50cc would work just about as well.
Terbo Speghetti /
Get a reed kit and run your stock pipe for a nice hp increase that won't make the power delivery too peaky. The idea that you'll "blow up" a cylinder with a small pipe is kind of an urban legend. It just spreads out the power and lowers the peaks.
Probably Fred /
I’m in total agreement because inside a stock maxi pipe is this thing not a chamber
When this is needed for proper compression psi boost,
Angry Hipster /
Thanks guys it's good to know I have options. I tried a hi torque with mesh air filter and upjetted and stock pipe. It moved me along great up to about 25mph or so and that's really all I want just as long as it can get me up to speed and pull me up a hill.
> not a chamber
Even though i still have to restrict my mopeds to about 37mph i still wont use an exhaust as shitty as the stock one.
Probably Fred /
> mesh air filter and upjetted and stock pipe. It moved me along great upd pipe your
Most bicycles can do 25mph,
If you can’t get around 35 mph with good takeoff out of a stock puch cylinder and exhaust with just filter, tuning/jetting changes you’re doing something wrong.
This pinto I had a put a high torque number 22 top end on it, performance filter and upjetted the carburetor, I used the stock exhaust too. the stock exhaust has slightly longer header than a maxi but basically is the same as one, hit 35 mph easy,
